Solved
Will CORSAIR CX430 [430W] PSU runs my XFX RADEON HD5770 card ??
  • Graphics Cards
  • Corsair
  • Radeon
  • Graphics
April 30, 2011 3:58:04 PM
Will CORSAIR CX430 [430W] PSU runs my XFX RADEON HD5770 [1Gb DDR5] GPU...?
My system specs are...
Intel CORE 2 Duo E7200 @ 2.53Ghz
Main Board model: Intel DG31PR
HDD: 1TB Seagate + 160GB
Chip set: G33/G31 Express Chip set Family.
Transcend 4GB RAM DDR2 667Mhz
CRT monitor with 1024x768 resolution.
Is XFX HD5770 for 1024x768 resolution screen a good selection...??
I will be buying a new monitor in over a one or two three years later...
Is this card good selection for my present monitor..??
Or Any suggestions..???
I LOVE GAMING CARDS...
Pl z need best answers...
More about : corsair cx430 430w psu runs xfx radeon hd5770 card
a c 1430 U Graphics card
April 30, 2011 4:31:47 PM
Yes it will!
m
l
a b U Graphics card
April 30, 2011 4:39:17 PM
You can get much better units in that price range but if you can get it cheaper than retail price then go ahead.
m
l
a c 130 U Graphics card
April 30, 2011 4:42:03 PM
Yes its fine Corsair are a top manufacturer.
Mactronix :)
m
l
April 30, 2011 4:43:34 PM
m
l
a b U Graphics card
April 30, 2011 6:27:03 PM
At 1024x768 an HD5670 is more appropriate, certainly.
Mactronix :)
Not really, the decent units (HX & TX) are made by Seasonic.
m
l
April 30, 2011 6:42:59 PM
It is almost an overkill but you will be happy if you upgrade your monitor in the lifetime of the card.
m
l
May 1, 2011 2:04:11 AM
If I buy HD5670 GPU for my 1024x768 resolution PC,
Will HD5670 makes the FUTURE GAMES playable (even in 1680x1050 resolution) ...???
or else,
If I buy HD5770 GPU for my 1024x768 resolution PC,
Since, HD5770 gives constrained performance with 1024x768 resolution, Will the performance of it gets affected on the new monitor [may be 20"], which I will be buying one or two years later...???
m
l
May 1, 2011 6:21:51 AM
HD5670 will do OK at 1680x1050 where an HD5770 will do great. Even if the HD5770 does not have the same performance advantage over the HD5670 at 1024x768 it will be better.
m
l
May 1, 2011 9:53:22 AM
ok fine..these are my last questions...
1.Will HD5770 works fine with my 1024x768 monitor..??
2.Will HD5770 struggles to perform in my low resolution monitor..??
or else
3.Shall I go with HD5670 or HD5750..??
m
l
Best solution
May 1, 2011 9:58:25 AM
1 Yes!
2 No!
3 I would stick with the HD5770 (when you upgrade your monitor you will not regret it)
a c 177 U Graphics card
May 1, 2011 10:42:00 AM
just get the 5770.
m
l
May 1, 2011 11:47:04 AM
Best answer selected by bairav.
m
l
May 3, 2011 7:09:24 PM
Your information is incomplete and inaccurate.
m
l
May 3, 2011 7:52:36 PM
I just couldn't be bothered with it but yea as you said not a clue
Mactronix :)
m
l
