Hello and thanks for entering my thread
All of these items are being thrown inside of a ATX Mid Tower Antec case;
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097
The Mobo has been chosen for its ability to run the new AMD Bulldozers when they are released, GIGABYTE GA-990XA-UD3 AM3+ AMD 990X 4x240 pin memory slots, DDR3 2000(O.C.)/1866/1600/1333/1066.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128510&cm_re=gigabyte_ud3-_-13-128-510-_-Product
Until the Bulldozers are unleashed, it will be running a AMD 1100t Phenom II
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103913&cm_re=amd_1100t-_-19-103-913-_-Product
The ram is what I am the most unsure of. I have landed on the G.skill Sniper series 8gb (2x4gb) DDR3 1866 Dual channel seen here
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
The G.Skill sniper series seems to be the choice of most gamers and runs a little cheaper than my original selection, the Corsair Vengeance 8gb (2x4gb) DDR3 1866 dual channel, seen here
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233142&cm_re=corsair_Vengeance-_-20-233-142-_-Product
I want to run with the G.Skill, if it is viable for this build of course, unless someone knows something I don't (which wouldn't take much).
All of this is going to be powered on a Corsair GS600 600w PSU. Graphics delivered by the EVGA GeForce GTX470 1280mb GDDR5 GPU.
Thank you for your time!
(Edited, I Hope this helps.)
