Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > [Solved] 5850 Power Supply
Forum Graphics & Displays : AMD Radeon [Solved] 5850 Power Supply
Best answer from jb6684.
Hey guys, yesterday I posted a question about the GTX 460. I was told that the 5850 was a much better card for only a couple bucks more, but to use it I need to upgrade my PSU. So I'm wondering what power supply to get. The card requires a 500 W power supply and I need more to power everything else. So what supply should get? Should I stick with the GTX 460 or the 550 Ti and just forget the 5850? I'm a total PC noob so I'm sort of lost here:P
Reply to NinjaDude03
Current ATI/AMD card are a bit more efficient than Nvidia counterparts. a 5850 consumes as much power a stock 460GTX, a 560Ti is faster, but consumes more power.
A 460GTX is a shorter card, so that could make a difference as well depending on your case.
Either way, a you will want a PSU with at least 40A on the 12v rail or maybe a pair of 25A 12v rails.
http://www.newegg.com/Product/Prod [...] 6817341017
Good PSU right there for a great price!
------------------------------ AMD Phenom II 955 X4 3.8GHz -- Hyper 212 Plus
6GB DDR2-800 4-4-4-12 -- XFX 6850 OC (850/1050) -- Gigabyte 785G AM2+
NZXT Hades case -- NZXT Hale90 650W PSU
Reply to vilenjan
A single reference clocked GeForce GTX 460 has a Maximum Graphics Card Power 160 Watts. This means the card will draw up to a maximum of 13.3 Amps from the +12 Volt rails.
A single reference clocked Radeon HD 5850 has a Maximum board power of 151 Watts. This means the card will draw up to a maximum of 12.6 Amps from the +12 Volt rails.
A minimum of a 450 Watt or greater system power supply with a minimum +12 Volt current rating of 24 Amps or greater is recommended for either one of those single graphics card configurations. The power supply must also have at least two 6-pin PCI Express Supplementary power connectors.
Select from reputable power supply name brands such as Antec, Corsair, Enermax, Seasonic, XFX.
You haven't specified a budget or whether you want a modular power supply unit.
Reply to ko888
ko888, not gonna be mean, but shooting for the bare minimum in never a good idea. Yes a 450W PSU with about 30A on 12 rail will probably work, but cutting it that close means that the PSU will work hard most of the time, reducing its overall lifespan. Also Msot 450W or lower PSU only have a single PCI-e connector, so he would have to use a molex to PCI-e adapter with those PSUs.
My system loads around 50%-60% on my PSU, some might say this is wasted, but most PSU are most efficient at around 50% load, and I hope to get a long life out of mine since I dont stress it.
Reply to vilenjan
Here's a list that shows some recommended PS sizes for specific cards....
http://www.realhardtechx.com/index [...] age362.htm
Too many people under estimate the importance of a strong, quality power supply. Choose one from Corsair, Antec TP, or Seasonic...
650watts will work for any single GPU system.
850Watts will work for all but the highest end dual GPU systems.
A good power supply will out last the usefulness of a build, may be two builds. So, plan ahead 650watts min size...
------------------------------ If you can't decide, just get both.
Reply to jb6684
my budget right now when considering the GTX460, GTX 550 Ti or the 5850 and the PSU is perhaps at MAXIMUM $250. I would prefer not to get past the $225 mark but I also want to avoid cheap brands. That OCZ 600W that you linked me to looks really nice and within my budget but is it compatible with my setup?
Sorry for not posting my specs before. This is what I have right now (AKA crap)
AMD 880G motherboard
AMD Athlon II X4 635
1TB SATA HDD (don't know what brand)
4GB DDR3 RAM (again, unspecified brand)
ATI Radeon HD 4250 integrated graphics
Super Multi DVD Drive w/ Burner
And a crappy 250W power supply:P
My RAM and my processor is fine for now but I want to upgrade to a Radeon HD 5850 and a modular PSU.
I only specified the minimum requirement so that the OP doesn't purchase something below it and wonder why the system doesn't work properly. I already knew that a power supply's maximum efficiency is reached at 50% load.
Reply to ko888
That's a little thin for a GPU & PS but, REBATEs will make up the difference:
GPU, $158... GTX 460..
http://www.newegg.com/Product/Prod [...] 6814121391
Power Supply: $50... 600watt
http://www.newegg.com/Product/Prod [...] 6817139019
or
http://www.newegg.com/Product/Prod [...] 6817371031
Reply to jb6684
Do you guys think that is will work?
GPU: Pretty much the same as you suggested jb6684 but cheaper because it is the 768MB version. http://www.newegg.com/Product/Prod [...] 6814121390
PSU: another antec.
http://www.newegg.com/Product/Prod [...] 6817371015
ASUS and Antec are pretty reputable brands aren't they?
Best answer
Those will work. But the 1Gb card would be better and it's only $3 more after REBATE....
Reply to jb6684
Alright, thanks for all your help guys!
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1823 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in these cards is only the factory OC right?
By fantastik250, 42 minutes ago:
I should say that is the only difference.
Best offers
Top experts
