AsRock Z77 Extreme4 turning on problems
Related ressources
I can't unplug them from the case, sadly; they're trapped in a small mesh cage at the front of the case. The case is quite old, so it might have just died on me.
I used the stand offs and I checked the GPU cables and suprise! I didn't have my GPU plugged in. Could that have stopped a power on?
Pics are taking a while, sorry.
Motherboard Master
No. Remove it out of the case, the mobo and PSU.
Plug it in the mobo outside of the case on the box u got it in.
CPU has to be installed. Check if it is correctly installed. Than the RAM, also installed.
Than the PSU connected with 8pin/24pin/CPU fan connected to the mobo as well.
Than connect the GPU to your monitor, plug the monitor in the power.
It should boot in the BIOS only.
If not, its bad PSU or mobo.
derpaaa said:
I plugged everything back in and put in the power plug. My headset lights came on and the LAN Port LED flashed orange, which means "data activity". Any insight on where to go from here?
So I know this thread is from last year, but I am curious if you ever got this resolved. I just purchased the same board, and I am having the exact same issues. Paperclip test passes, but nothing happens when I press the Power Button.
Yeah, I just got it replaced with the warranty I bought with the board. New one worked like a charm.
