Hi,
This is my first post so apologies as i am still slightly noobish.
I built my first pc a few months ago and just through in a 80mm fan. Now looking at the internal temps i would like to drop them down as soon i will be purchasing a GPU and using this rig as my main gaming system. So far i have moved the 80mm fan to the front of the case as an intake. I have just ordered another of the same fans to place at the back as an extractor fan along with the PSU fan.
If i was to mount another 2 80mm fans (as they are not overly powerful) on the side would they be ok as intakes so i could drop the temp as low as possible?
I can supply pics if needed.
My system spec is:
Asus M4A78LT-M
2 x 2gb DDR3 1333mhz
AMD Athlon II x4 645 3.1ghz
Seagate 500gb 7200rpm 32mb HDD
DVD+/- RW
1 x Akasa 80 mm Blue LED Intake Fan
My system spec is:
Asus M4A78LT-M
DVD+/- RW
