Hi everyone, this is my first post here and I'm really looking forward to your suggestions! Thanks in advance for your help...
System Specs - Purchased September 2009
OS: Windows 7 Home Premium
CPU: 2.20GHz AMD Phenom 9550 Quad-Core
MB: PEGATRON CORPORATION VIOLET 3.02
RAM: 8GB PC2-6400 DDR2
HDD: 1TB SATA 7200RPM
GFX: NVIDIA GeForce 9300GE (256MB Dedicated)
Dual monitors, card must support at least (1) HDMI and (1) VGA or DVI
BluRay/DVD, Built-in Wifi Adapter
I need an upgraded video card without a doubt, and I need a new hard drive, as I've got a gut feeling the one I have now is about to fail. Needs to be minimum 500GB.
Now, the budget... I want to spend no more than $300. Everything in -- shipping, etc.
It would be awesome if you could give me options for just a HDD/GFX Card upgrade to start, and then even other upgrade options I could go for. All will be ordered online through NCIX/Newegg/TigerDirect -- It would be AWESOME if you could post links and/or prices.
Thank-you so much! This is my first attempt at upgrading a computer, and I'm looking forward to the end result
EDIT >> Forgot to mention, I'm in Canada BUT I can get parts shipped to the US and I'll go get them across the line if the product+shipping is cheaper. Just add $5 per part if it's from the US. Thanks!
