Hello everyone,
I recently purchased a Palit HD 4850 for a build that I am slowly purchasing parts for. I was testing it in the budget system I built for my wife a while back (see specs below). I was planning on crossfiring it with another HD 4850 but I cannot get the drivers to work properly on this card.
Problem:
The catalyst drivers will crash and restart (sometimes BSOD) whenever I have multiple windows open and when I try to save a openoffice document. Here is the catch it will run fine with the default windows drivers (no AMD drivers). I have tried all the 11.x drivers up to 11.4 with no success. Each time I uninstalled, restarted, then installed the new driver. The fan works fine, although it sounds like a jet engine at 50%. My Sapphire HD 4770 works absolutely fine with the catalyst drivers.
My guess of the cause:
Failing GPU, my janeky PSU, maybe driver issue.
My options are to sell it on Ebay as for parts/not working and try to recover some of my losses. Or I can wait till I finish the new build (about three months time) with a good PSU and test it then. If I sell it I am gonna put the money towards the Sapphire HD 5850 extreme on the egg so I don't get stuck with another lemon.
So the question is do you think it is the card or the PSU?
Thanks for any and all help!
Specs:
CPU: AMD Athlon II x3 450
M/B: Asus M4A88TD-V EVO
Ram: G-skill 2x2Gb 1600MHz 9-9-9-24 1.5v
Hard drive: WD 250Gb caviar blue
PSU: Raidmax 500W 22A across a single +12v rail (bundled with case I know now this was a bad decision)
GPU: usually a Sapphire HD 4770 but the problem one is the Palit HD 4850
Case: Raidmax smilodon (I hate this case but the wife wanted it cause she loves green)
Monitor: My old RCA 32" 720P LCD TV
Problem:
Specs:
