Closed Solved
Will a GeForce 7900 GTX work on my system?
Hey everyone I was currently looking at upgrading my graphics card because my computer is 5 years old now and I am experiencing some artifict with my games (SCII and Portal 2 for some). This also included some graphics failing just prior to a crash. I cleaned out my box of all dust and it improved it slightly, but not 100%. I'm pretty sure my card is just not powerful enough and I'm really worried because when i monitor the Temp using NVidia software it says its peaking at 110C during games, which i Know is its limit. I think my card is just not powerful enough and stressed.
I currently have an NVidia 7900 GS and was looking to upgrade to either the NVidia 9500 GT or the NVidia 7900 GTX. I am confident my system will run the 9500 GT fine, but was wondering if it could handle the 7900 GTX. My Max power supply is 375 W and the 7900 GTX recommends 400 W (but i have seen places that say 350-400W). Thanks!
PS I play video games socially, but I still like them to look semi good and at least run properly without artifact. My budget is $100 or less about right now (I've found both cards online for less). If you can think of a better card for me please let me know!
Comp Specs:
Manufacturer : Dell XPS DXPO51
Mainboard : Dell 0FJ030
Chipset : Intel 945P
Processor : Intel Pentium XE 940 @ 3200MHz
Physical Memory : 4096MB (4 x 1024 DDR2-SDRAM )
Video Card : NVIDIA GeForce 7900 GS
Hard Disk : Seagate ST3320633AS (320GB)
DVD-Rom Drive : Toshiba-Samsung DVD-ROM TS-H352C
DVD-Rom Drive : Optiarc DVD+-RW ND-3570A
DVD-Rom Drive : JW5836D HUD482O
Monitor Type : Dell Computer DELL 1704FPT - 17 inches
Monitor Type : Dell Computer DELL E207WFP - 20 inches
Network Card : Intel PRO/1000 PL Network Connection
Network Card : Ralink Technology RT2561/RT61 802.11g PCI
Operating System : Microsoft Windows XP Professional Media Center 5.01.2600 Service Pack 3 (32-bit)
DirectX : Version 9.0c (April 2009)
7 answers Last reply Best Answer
More about will geforce 7900 work system
  1. Do you have the stock power supply or have you updated it? If you have a good PSU then it will work but it is highly recommended to upgrade your PSU.
  2. Best answer
    Don't know where you're shopping but you can do better than a 7900 GTX
    9800 GT
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6820707&CatId=3670
    Greater performance, lower cost and will work with your psu.
  3. ^Agreed. The 7900 is far too outdated by now.
    No it is the stock and like a I mentioned it says max is 375W. I was told my computer is kinda of old and to not waste my money upgrading both my card and my PSU. So I figured Id but an upgrade but obviously not the best product out there.
  5. Best answer selected by dml5064.
    9800 GT
    oh wow!!! Thank you that is prefect! I was looking at that card earlier but the NVidia site said it required 400W but this one is 350W thanks so much!
  7. This topic has been closed by Mousemonkey
Graphics Cards Graphics
