Working on my first build, a htpc.
I connected my components to breadboard them shorted the switch jumpers, and no post.
I went through the Toms no post troubleshooting, and eventually removed all ram sticks and got the loud memory error tones.
From there I took another look at my mobo manufacturers website, and found that the ram I purchased was not listed as tested compatible, is this likely the source of my non-posting, and thus worth the RMA and reorder expense, or are there other things I can look for?
Thanks!
mobo: ASRock H67M-ITX LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
cpu: Intel Pentium G620 Sandy Bridge 2.6GHz LGA 1155 65W Dual-Core Desktop Processor BX80623G620
ram: G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL8D-4GBXM
Thanks!
