Does this build work for ~$800
Here are my parts.
Case: 69.99 Antec Three Hundred
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
GPU: 169.99 6850 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
CPU/Motherboard: 332.98 I5 2500k and MSI P67A-G45
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.660241
PSU: 69.99 Corsair 600W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
RAM/DVD: 71.48 Seagate Barracuda 1TB 7200 RPM SATA 6
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.679807
OS: 94.99 Windows 7 64 bit
Total: $798.41 after rebates
Questions:
1) Are these parts compatible?
2) Is this a good build for the price?
3) Could i throw in another 6850 a year or so from now to stay up to date?
Thanks guys and input is appreciated.
1 answer Last reply
More about does build work
  1. 1) Yes.
    2) Pretty good.
    3) Yea.
    I would change the power supply.
    Antec High Current Gamer HCG-520 80Plus Bronze $55 (10% off Promo code available)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371047
    As it is just as powerful, despite what it says on the box. They both have a 40A 12V rail, the Corsair only has 1 extra amp on each of the 3.3 and 5V rails.
    The main reasons why I would choose the Antec over the Corsair are because it is more efficient and has a higher temperature rating, which points to better internal build quality.
    You also don't have to deal with a rebate, not that that would necessarily be an issue anyway, but still...
New Build Systems Product
