Closed Solved
GTX 580 SLI PSU Problems
Sup,
I just built my PC and I was wondering if my PSU is dangerously low in terms of wattage to support to SLI GTX 580's.
Current Setup:
ASUS MAXIMUS IV EXTREME P67 Mobo
i7 2600K OC @ 5.0Ghz
8GB DDR3 1600Mhz Ram
OCZ 240GB SATA III SSD
WD 2TB 7200RPM SATA III HDD
SONY CD/DVD Reader/Writer
ZALMAN 165mm CPU Cooler
2x ZOTAC AMP! 1.5GB GTX 580 OC'd Clock/Shader Clock
COOLER MASTER Silent Pro RS850-AMBAJ3-US 850W ATX12V v2.3 / EPS12V v2.92 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171048
Do I have to upgrade to 1000W to support the above requirements?
Thanks
3 answers Last reply Best Answer
More about problems
  1. Best answer
  2. Best answer selected by light07x.
  3. This topic has been closed by Mousemonkey
Graphics Cards Gtx SLI Graphics Product
