Hello,
I have a ZooStorm PC Intel 650 3.2Ghz 8gb with a Foxconn H55MXV motherboard formfactor 24.4x21.8cm, I need advice on Graphic Cards, I need a card that can handle 3 or more monitors as I've got 3 Viewsonic monitors 2 have DVI and the other has HDMI connector want at least PCI-e x16 2, 1gb DDR5, also been advised it should be 22cm max and minimum 1900x1200 resolution
and if I need a PSU what should I get??
Unless there is a better/cheaper way of doing this
