Closed Solved
Patriot 2133mhz ram reverts to 1333mhz on X79 mobo
I have Patriot 16GB (4 x 4GB) PC-17000 (2133MHz) Enhanced Latency Quad Kit on the RIVE
http://www.frys.com/product/7021331?site=sr:SEARCH:MAIN_RSLT_PG
The memory reverts to 1333mhz and I can't get it to boot windows when set at 2133mhz. I've tried 11-11-11-27 1.5v & 11-11-11-30 1.65v (as stated by the official Patiot website) and neither work. Anyone know some settings that will work for these at 2133?
6 answers Last reply Best Answer
More about patriot 2133mhz reverts 1333mhz mobo
  1. PXQ316G2133ELQK
    DDR3-2133 11-11-11-27 @ 1.50v - http://www.patriotmemory.com/product/detail.jsp?prodline=5&catid=34&prodgroupid=221&id=1239&type=1
    DDR3-2133 11-11-11-27 @ 1.65v - http://www.patriotmemory.com/product/specs/PXQ316G2133ELQK.pdf
    Interesting specs I must say, and oddly quick that it was Deactived.
    Q - What ASUS X79?
    Q - What values are listed in the 'SPD' tab of CPU-z?
    CPU-z - http://www.cpuid.com/softwares/cpu-z.html
    SPD tab (just the 'XMP column') - http://www.cpuid.com/medias/images/en/softwares-cpuz-05.jpg
    BIOS:
    F5 Load Defaults, and modify other BIOS settings as needed
    AI Overclock Tuner -> XMP & Profile1
    VCCSA -> Manual
    VCCSA Voltage -> 1.20v
    F10 Save & Exit = Yes
  2. Yes Jaquith these have to be the worst ram i have every own.
    -I just got the Rampage IV Extreme mobo flashed bios to newest version1404
    -CPU-Z: XMP-2134: 1067mhz, tRC 51, Command Rate 3T, voltage 1.650v
    Bios Profile- states VCSSA 1.350v, I set it before with no luck, but ill give 1.20v a shot
  3. Best answer
    I mean this very sincerely, RMA that kit for something else like they're the plague, and do not I repeat do not allow the VCSSA Voltage >1.20v so run them at their Defaults.
    There are (2) two voltages that are known to permanently degrade the SB-E CPU: 1. vCore of 1.55v and higher and 2. VCCSA of 1.35v and higher. This permanent degradation happens in a matter of hours and not days, weeks or months, but hours!
    So I can certainly understand why those kits have been Deactived so quickly. We might as well play air hockey with your CPU -- it would be safer for it.
    Please heed my advice. I concur those are indeed the worst kits I ever seen and worst a real danger -- it's scary that Patriot would have allowed them to be sold.
  4. Ok will do. Many thanks Jaquith.
  5. Best answer selected by Swolern.
  6. This topic has been closed by Nikorr
Asus Patriot RAM Motherboards
