jemtray
47
Hi guy's, I am wondering if the 500w power supply I am using now will be sufficient enough to power my new config,
It consist's of; AMD II Quad core 965, 3.4ghz, 8gb Crucial DDR3 1333 mhz, ATI Radeon 5500, Creative pci sound card,
750 gb hard drive, 24x dvd r-+rw MB; ASUS M4A88T-V EVO Series usb3. thanks in advance.
jerreddredd
1,477
Well it's not a real stellar brand, but if lives up to it's stats below then it should work. just don't go putting a big GPU on it. it only has 20A 12v rail.
HEC X-POWER ATX-500TD
OVP (Over-Voltage Protection)
UVP (Under-Voltage Protection)
OPP (Over-Power Protection)
UPP (Short-Circuit Protection)
Dual 80mm fans deliver extra-quiet cooling and maximum airflow
High Efficiency ( > 75%)
High energy power with low ripple noise
100% Hi-pot, Chroma & Burn-in function tested
Input / Output Characteristics
Input Characteristics
Voltage 230Vac/50Hz
Output
+3.3V ------36A
+5V---------36A
+12V-------20A
-5V----------1A
-12V--------1A
+5VSB------2A
Connectors
Universal 20 + 4 Pin Main ATX Power Connector X 1
4 Pin + 12V Power Connector X 1
6 Pin Power Connector for PCI Express Graphic Card X 1
Peripheral Connector (4 Pin for HDD, DVD … etc) x 6
Floppy Connector (4 Pin) X 2
Serial ATA Power Connector X 1
24 Pin + 8 Pin adapter for AMD ATXGES X 1
jemtray
47
I am in the U.K.
jerreddredd
1,477
