HAF 912 Plus; right side panel stuck
Last response: in Components
October 13, 2011 12:23:22 PM
Hey Guys,
Just started my first build today but I hit a snag early on :( . The Right side panel of my Cooler Master HAF 912 Plus won't budge. I have removed the screws just like on the left side but when I go to slide it off it's jammed. I've been at this for over 4 hours now and still nothing.
Has anyone ever had this problem with a HAF 912 before, or any case for that matter?
I'd really appreciate any help on this one, rather not have to send the case back.
Cheers
October 13, 2011 1:37:29 PM
try to press the side panel to the chassis wen u remove it. i've got a haf 922 and had the same issue in the beginning. all i did was gently push the side panel againt the case and then it slid out pretty easy. try it,,,,,,or mayb it was just mine :??:
October 13, 2011 1:58:12 PM
Thanks TheNismo1, just got it off, had to use a hell of alot of force and someone else pushing it in. Phew...Two man job (well 1x woman) :D  .
October 13, 2011 2:09:08 PM
lol....dunno y it does that...all my friends has cm chassis also, and the 1st time all got stuck. anyway, njoy ur build buddy :)
