First heres the system
Cooler Master GX 750W
ASRock Extreme3 870
Amd Phenom II x2 555
XFX Radeon hd 6850 1GB
2 x 2GB PNY XLR8 1600 ddr3(8-8-8-24)
Seagate Barracuda 1TB 7200 Sata 6Gb
Hitachi deskstar 7200 400GB Sata 3Gb
Sony dvd burner
NZXT Phantom stock cooling
Windows 7 Pro 64bit
Seems to get random BSOD, more noticeably during software installations, 3dmark benching, and video playback. Doing simple tasks such as writing this up seem to do nothing.
Thought maybe it was the memory as it did it frequently during windows startup but those went away as i believe that was issue with dual booting, which i got rid of. I removed one stick of ram thinking that one was the cause and seemed to of helped, but now i'm getting them again. So I put both sticks back in and ran memtest for one test and they passed even though the windows memory test i did 2 days ago said hardware failed. I am gonna let memtest run over night to make sure.
I know the PSU should have plenty of power, crashing during 3dmark and video playback makes me wonder about the gpu, unless the psu is bad. Idle 12V is 12.2ish going by sensor and not multimeter.
The motherboard has 8pin 12v connecter but is stated it will also work as a 4pin, the psu can use either, would that change anything? Right now its being used as a 4pin
ASRock Extreme3 870
Sony dvd burner
Windows 7 Pro 64bit
