Radeon HD 5970 Problems
SuperTweaker
hello there. I recently built my own gaming rig several days ago. The Problem is, my Games tends to freeze upon gameplay. Weird thing is, if i disable catalyst AI or Uninstall one of the display Adapters in the device manager (there's 2, probably cuz 5970 consist of 2 GPUs), the freezing stops. But in return, My Performance has been cut into half. So i suspect that something is wrong with the 5970. i can't Purchase another Graphic card cuz my parents won't allow me, so i've figured i have to solve this problem by myself. So why is it that when there are 2 GPus running on the 5970, it tends to freeze while running 5970 on a single GPU stops the freezing issue? I'm Using the catalyst 11.4 Driver btw
Notes: i noticed in the event viewer, theres a log. it mentioned something about "Audits has been dropped by transports. 0"
Help me, tomshardware members, your my only hope :D
