I just reinstalled windows 7 64bit and a new hard drive after my HDD failed. I plugged in my wired connection and it detects the network and then it disables it after 2 seconds. Then it enables again and disables.. continually.
I tried a wireless card too but it detects the network and asks for a passphrase but it says my passphrase is incorrect even though it's right. I triple checked it...
I have windows firewall turned off and I don't have any other firewalls. I rebooted the network and my computer too.
If I go to Network Connections in the Control Panel, it shows:
-Local Area Connection
it cycles between these every other second:
---Enabled
---Identifying Network
---Network Cable unplugged
---Enabled
