PSU problem???Help me out pls
Hey guys, I just build a pc yesterday and when I turn on the button from the PSU everthing went ok the green led from my MOBO lighted up, and everything looked fine, but at moment I pressed the START button from my case my PSU started blinking its BLUE LED and the LED's from case didnt light at all, 10-15 secs after this, my system started finally, I though I was cause my MoBo and Proc were new, but today at morning when I try to start my PC it happened again!!!!, It need 10-15 secs to start correctly,I dont know if it is PSU problem, cause it is a Zalman 600W HP PSU, and my setup is
Proce:Phenom II X6 1090T 3.2
MoBo:Asus M4A88T-M/USB3
Memory:2x2GB DDR3 1333MHZ Patriot Sector 5 Gseries
250Gb HDD Seagate
Any help will be appreciate very much ,thx for reading
2 answers Last reply
More about problem help
  1. Are you using the Windows Sleep function? that actually when you press the start button, it tries to put your saved state back to RAM?
  2. Nop, But actually I just fixed I made a mistake wiring the MoBo :D ty very much, now im focusing on Memory Ram problem
Power Supplies LED Monitor Components
