Solved
500 watt power supply in a 305 watt system
can anyone tell me if replacing a 305 watt power supply in a dell 4700 with a 500 watt would be okay ?
6 answers Last reply Best Answer
More about watt power supply watt system
  1. Best answer
    i believe some dells use a Proprietary powersupply. so you need to know for certain if the replacement is 100% compatible
    its not like most other pcs where you can stick any psu in--unfortunately i dont know which model dells use this--so you may need to look on dell support to find out
    but i would be cautious of anyone saying of course you can stick any psu you want in unless they really know for a fact that model isnt Proprietary
    http://support.dell.com/support/edocs/systems/dim4700/sm/parts.htm#wp1055681
    ...you're really lucky! It's not proprietary... you're good to just don't order from Dell. lol :o
  3. I would suggest a semi-modular psu if you're using the oem enclosure.
    OCZ ModXStream Pro 500W - $54.99 USD/$34.99 USD after mir
    http://us.ncix.com/products/?sku=33040&vpn=OCZ500MXSP&manufacture=OCZ%20Technology&promoid=1339
    Canadian link
    http://ncix.com/products/index.php?sku=33040&vpn=OCZ500MXSP&manufacture=OCZ%20Technology&promoid=1366
  4. Best answer selected by gigs66.
  5. Strange BA, russwood had it right
    All good bro, just hope he read the link as it's in his best interest.
Power Supplies Dell Components
