Quick question. I am building a new computer using the fractal design R3 case.
As i am trying to keep the computer as quiet as possible, I have devided to go for nexus 120mm fans, as I have read many many good reviews on how quiet they feel.
The case comes with 2 build in fans from Fractal Design, and I am getting 5 more Nexus fans (3 for the case, and 2 for the cpu's heatsink.
Now here is my question : Should i buy 2 extra nexus fans to replace the case's default fans. I haven't had found any reviews to compare noise made by fractal design's fans and nexus's. The nexus fans also comes with rubber pieces to replace screws, which the case is not using.
Has anyone used fractal design and nexus' fans? are they as quiet?
Thanks.
Thanks.
