Hello all,
I just finished a new budget build using an Athlon II X3 450 Processor and MSI 760 GM-P35 Motherboard.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103886
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130560&Tpk=msi%20760gm%20p35
My problem is that the processor defaults to 2.2 ghz while the processor is rated to run at 3.2 ghz. I found out the motherboard keeps setting the CPU multiplier to 11x (FSB at 200 Mhz) hence the processor runs at 2.2 ghz. I can't change the multiplier (I can only set it to "Auto") so I'm a bit clueless on how to resolve this issue.
Any help or insight would be greatly appreciated.
