HELP! Can I run GTA 4 on this build?
Case: CoolerMaster Elite 430 Mid-Tower Gaming Case with Side Panel Window
Freebies: None
Internal USB Extension Module: None
Neon Light Upgrade: None
Extra Case Fan Upgrade: Default case fans
Noise Reduction Technology: None
CPU: AMD Athlon™II X4 645 Quad-Core CPU w/ HyperTransport Technology
Freebies: None
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
Motherboard: Asus M4N68T-M V2 AM3 DDR3 NVIDIA Geforce 7025/nForce 630a Chipset mATX w/ Onboard Graphics and Core Unlocker, 7.1 HD Audio, GbLAN, USB 2.0, SATA-II RAID, 1 Gen2 PCIe, 1 PCIe X1 & 2 PCI
Memory: 4GB (2GBx2) DDR3/1600MHz Dual Channel Memory Module (Corsair XMS Gaming Memory with Heatsink Spreader)
Video Card: AMD Radeon HD 6570 1GB GDDR3 16X PCIe Video Card [+34] (Major Brand Powered by ATI)
Freebies: None
Video Card 2: None
Video Card 3: None
Dedicated PHYSX Card: None
Free Game: None
Multiple Video Card Settings: Non-SLI/Non-CrossFireX Mode Supports Multiple Monitors
Power Supply Upgrade: 700 Watts - XtremeGear SLI/CrossFireX Ready Power Supply [+36]
Hard Drive: 1TB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD [+18] (Single Hard Drive)
Freebies: None
Data Hard Drive: None
Hard Drive Cooling Fan: None
External Hard Drive (USB3.0/2.0/eSATA): None
USB Flash Drive: None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Optical Drive 2: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
3D Vision Glasses: None
Freebies: None
LCD Monitor: None
2nd Monitor: None
3rd Monitor: None
Speakers: None
Network: Onboard Gigabit LAN Network
Network Switch: None
Keyboard: Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard
Mouse: XtremeGear Optical USB 3 Buttons Gaming Mouse
Mouse Pad: None
Gaming Gear: None
Extra Thermal Display: None
Wireless 802.11B/G Network Card: None
External Wireless Network Card: None
Wireless 802.11 B/G/N Access Point: None
Bluetooth: None
Flash Media Reader/Writer: INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
Video Camera: None
Headset: None
Printer: None
Cable: None
Power Protection: None
Surge Protector: None
IEEE1394 Card: None
Internal USB Port: Built-in USB 2.0 Ports
USB Port: None
Operating System: None - FORMAT HARD DRIVE ONLY [-83]
That is what I have so far. Now, Could this run GTA IV at ~40 fps on medium to high settings? If not, what other components could I cut out of the build to make room for A better CPU/GPU? Also, do you see anything I am missing? I don't know too much about computers, that's why I am ordering one. Any help is appreciated. Thanks.
4 answers Last reply
More about help build
  1. Where are you ordering it from?
    Either way you'de probably want something a little stronger as a video card, I've noticed GTA is tough on benchmarks, and that card is mediocre.
    It would play at low resolution (small screen), medium settings, and I doubt it would be 40 fps.
  2. Its from cyberpowerpc.com. Okay, so could you help me with a build under $650 that will run gta 4 at medium-high decently? Also, I was going to overclock it to 3.0ghz. Plus, I have seen videos of these cards running gta 4 well. Anyway...heres what the computer must have:
    Mouse and keyboard(don't have to be great)
    An OS(Vista or 7)
    Be able to run GTA 4 medium to high
    Must be built at a website
    Could you give me some pointers as to what to look for and what to avoid? Thanks.
  3. i have a hd 6570 1gb ddr3 of sapphire and i can run gta 4 on high visuals with shadows turned to low.
    resolution is 1280x768
  4. I run GTA 4 on a crap, entry EVGA GT 220 and I get ~30fps on that, also with a 2.8 Wolfdale Core 2 Duo. I play at 1440x900, everything medium. I've heard that the hd65xx cards are extremely similar to the hd56xx cards. I am starting a build myself and plan to get a HD5750.
New Build Systems
