I have a Radeon 4800 Series (ATI) card made by Visiontek (model 4350).
It has dual DVI-I Dual Link outputs and S-Video.
I ONLY have component cables at the PC (connecting into projector on other end for home theatre setup).
I tried a DVI to Component adapter which does not work on this board.
I tried an S-Video to Component adapter which does not work.
What are other choices?
If I need to replace this card, can you recommend one that supports digital output via DVI to component adapter?
THanks!
THanks!
