Help Setting Bios Settings
Hello i just built a new computer and I need a Pro to look over my bios settings to be sure everything is set to the correct settings I apreciate any help you can give if there is anything you see that needs to be changed please let me know thanks.
Extreme Tweaker
Main
Advanced
Power
Boot
Tools
2 answers Last reply
More about help setting bios settings
  1. I have also noticed one error when I first turn on my computer after several hours of having been power-off the system wont start-up the motherboard lights up and fans start but my screens stay blank until I do a hard powerdown and start it again then everything seems to start correct. I changed one setting in bios I changed Quick Boot: Enabled to Quick Boot: Disabled but im not sure if it helped the issue or not.
  2. Hello I still need some help. please I don't know if everything is set to proper settings for all bios settings
Homebuilt BIOS Computer Systems
