My pc have problem with power
Hello,
my pc power supply no power when i want to turn on it nothing pwer in CPU. How can i solve it?
My Motherboard thanks for advance
1 answer Last reply
More about problem power
  1. If the fan inside of the PSU is not spinning then it could be that the power supply unit is faulty or that the rocker switch I/O is not turned to ON (|), or that the power point mains plug is turned off or the mains power point is faulty or the PSU is of a higher/lower voltage than what is set in your country if you bought the PSU online.
Power Supplies Power Motherboards
