My friend has run into an interesting problem. We've recently wired his room for ethernet since he gets really poor wifi. The problem is his computer refuses to obtain an IP address or find the network. I've tried setting it to a static IP and my netbook is able to connect without issue. The other awkward part is if we connect his computer to his range extender using a cable it works fine.
I've tried a fresh install of Win 7 x64 ult, flashing his netgear wndr3700v2 with dd-wrt, redoing the cables, buying a new NIC to replace his onboard and resetting his cmos or at least that's everything I can remember.
I dont remember what motherboard it is, just that it's a MSI with an AMD chipset.
The range extender is Netgear WN2000RPT.
The NIC he bought is a Netgear GA311.
The house is wired with cat 5e.
