Help choosing the right LCD...
Guys, I'm planning to buy LCD (to replace my old crap CRT), but I have a question. Which LCD should I choose, between:
Full HD LCD with LED backlight but only has DVI port
http://www.lg.com/my/it-products/monitors/LG-monitors-E...
or
Full HD LCD + TV with HDMI port but not LED backlight
http://www.lg.com/id/it-product/monitor/LG-tv-monitor-M...
So which one should I choose? Is there any major difference (in quality and performance) between DVI and HDMI (besides of HDMI can carry audio)? I'm kinda confuse, and kinda new in LCD world. Thanks before. :sarcastic:
More about : choosing lcd
Do you need it to act as a TV and Monitor, if so get the one with the TV tuner card built in, plug in your ariel and monitor connection and dual use it as TV/Monitor, if you will not be using it as a TV then get the other LED backlight one!
Ask the community
