Solved
Power Supply Recommendation
Last response: in Components
Hey all, I am in the process of building my new computer and making all those tough decisions associated with this long and arduous process. I have a few things already locked in such as my processor, case, ram, and hard drive. The variable aspects of my build are the video card, motherboard, and power supply.
During my research for my build, I stumbled across this calculator that several people have linked: http://extreme.outervision.com/psucalculatorlite.jsp
My question is how accurate is this calculator?
My desired computer is as follows:
Core i5-2500K
Antec Three Hundred Illusion Case (with 2 120mm LED fans, 1 120mm fan, 1 140mm LED fan)
4 sticks of 4gb DDR3
500gb 7200RPM SATA HDD
AMD Radeon HD 6850
Entering my desired build resulted in a minimum psu of 286W and a recommended psu of 336W.
Based on these calculations I would purchase this psu: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
However, based on various forum posts regarding the PSU requirements of the HD6850 the recommendation was a minimum of a 500W psu and many people recommended 600-650W ones.
Would this Antec 430W psu work? If not, does this mean that the extreme psu calculator inaccurate?
Finally if the 430W psu does work, how much room would it allow me to upgrade my computer in the future such as adding a SSD (which I understand is very power efficient) and possibly a newer video card in a few years.
Best solution
Power supply Master
I don't really know how accurate that calculator is, but I would tend to accept its recommendation in this case. As 6850s are not power hungry at all, so people recommending 600-650W PSUs are overestimating power consumption, or possibly they believe that all units below that wattage level are not high quality.
So yes it will definitely work and there won't be any problem adding HDDs or SSDs (as long as you only use ~5 of them, as that is how many SATA connectors the EA-430D has). It would be fine with any graphics card that only requires one PCIe connector. Which I suppose could be quite restrictive as for instance 6870s aren't always that much more expensive than 6850s, but that requires two PCIe connectors, which might be beyond a 430W PSU.
I would like to share my experience at this point. The first GPU I bought was a 4890 which is relatively power hungry and requires two PCIe connectors. Soon I will be replacing it with a 6850 (mostly to reduce noise levels), it is less power hungry, cooler but it outperforms 4890s. So I think it will be entirely possible for you to remain in the 6850 power level and be happy with GPU upgrades.
Related ressources
Ask the community
