Startup problem
Hello, I startup on my computer, when windows load, my computer displays a blue screen of death. after sudden stop of my computer with the power button, Windows asks me to boot normally, I accept and after everything is working. I do not know what to do. sorry for my english, I'm French and my level is very low, thank you for your understanding and your help.
7 answers Last reply
More about startup problem
  1. Thank you for your links, but the problem is that I have already tried all that, I already made ​​my stress processor, made ​​a Memtest, try to change my RAM, nothing changes ...
  2. Your power supply is not providing adequate power to all of the hardware if it is less than 550 watts.
    If you list all of your PC specs including Power Supply Unit, OS, (dual boot? or virtual machine/drives) then a better reply would eventuate.
  3. This is my setup:
    750 watts Corsaire
    mother board ASUS asus p7h57dv- evo
    8Go DDR3 1600Mhz
    1To hard drive
    graphics card gtx 460
    this does not come from power (but thank you)
  4. nounours54 said:
    This is my setup:
    750 watts Corsaire
    8Go DDR3 1600Mhz
    1To hard drive
    My 2 cents,
    With my first build I put my 3.0Gbs Sata II 500Gb HDD in the Sata III spot since I thought that's how it was supposed to work. After a couple of blue screens I found out from my brother in law that I had placed it in the wrong Sata port. After that I had no problems. This might not be your problem but it helped me make sure I had all the wires and what not correctly placed from then on.
  5. Thank you, I try tonight, thank you very much
Asus Computer Displays Blue Screen Motherboards
