Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > [Solved] What Sound Card Should I Buy?
Forum CPU & Components : Sound Cards [Solved] What Sound Card Should I Buy?
Best answer from davcon.
I plan on buying the Corsair Gaming Audio Series SP2500 High-power 2.1 PC Speaker System, and was wondering what sound card (if any) should I buy?
Of course I'm going to just try it with my ASUS P8P67 MOBO first, but was looking for a little input and advice.
I also heard that many modern MOBO's have great onboard sound, but I wasn't sure about mine.
Thanks to all in advance for your help.
Reply to kllrfrk
You'll get lots of uninformed or non soundcard users that will argue that onboard sound is excellent.
It's not and you'll be doing yourself a disservice using onboard audio with that set.
As soon as you read someone referring to onboard audio as an onboard sound card,well i think you get my drift.
What's your budget?
Reply to davcon
What's your budget?
roughly $100, $150 if it's very great quality
ignore the double, sorry
Reply to kllrfrk
You can go back and delete post btw.
Where do you live? CAN/US?
Reply to davcon
US, why?
Reply to kllrfrk
Best answer
So i can recommend cards from appropriate sites.
Well balanced card does everything well - excels at gaming
AuzenTech Forte Low Profile PCI-E 7.1 - $119.21 USD
http://us.ncix.com/products/?sku=3 [...] =AuzenTech
Entry level high end card - excellent budget card
ASUS Xonar DX 7.1 Channels - $79.99/$59.99 after mir
http://www.newegg.com/Product/Prod [...] 6829132006
Newest Auzentech offering - not for gamers
Auzen X-Meridian 7.1 2G - under $150 hard to find
http://www.auzentech.com/site/prod [...] dian2g.php
There's plenty of cards out there but i wouldn't pay $150+ for a soundcard either.
I own 2 Auzentech cards including the Forte which is my main rig card.
It has been flawless since i bought it back in 2009.
Not a glitch or hiccup,pop, etc.
Owned at least 4 Creative soundcards back in 95/98/XP days.
Switched to Auzentech since Win7 much better driver support and great sounding cards.
Got tired of crappy Creative drivers and issues.
Let us know about those Corsairs i've been eyeing those up since they were released.
I prefer 2.1 speakers too.
Message quoted 1 times
Message edited by davcon on 10-18-2011 at 04:28:43 AM
Reply to davcon
Yea, thanks man will do. I've gotten a lot of good feedback, including from local stores (won't buy from there because they're pricey) and from a friend who had bought them. Too bad he's hundreds of miles away or i'd be able to hear them myself.
I think I'm going for the first one you posted, looks legit. That's the one you have? And also I listen to music if I'm not sleeping/working, so the AuzenTech Forte should be good for music too?
The reason I'm being so picky is that in most of the reviews I've read/heard about the Corsairs, you need a decent sound card for the sub to get your money's worth.
But thanks a ton for the help.
Edit: and wow, I love how they have the extension for the multiple aux plugs. I hate having to feel the back of the computer for 5minutes (then eventually turning the whole thing around) to find the spot
Message edited by kllrfrk on 10-18-2011 at 04:42:13 AM
Reply to kllrfrk
I'm very pleased with the Forte's music reproduction it's very good price/performance wise.
Btw i know what good gear should sound like.
I run a 8K+ home hi-fi set-up and that's just turntable/amp/pre-amp/and two speakers.
Been a hobby since i was a teen.
Metal rules!
Message edited by davcon on 10-18-2011 at 04:48:59 AM
Reply to davcon
^^ Good choices, the only addition I would make to the above list is the HT Omega Claro+:
http://us.ncix.com/products/?sku=2 [...] HT%20Omega
Reply to gamerk316
Metal rules!
Hell yes, metal forever.
Reply to kllrfrk
Best answer selected by kllrfrk.
------------------------------ Best answer from Digital Dissent:
Rollo=Fanboi
Reply to kllrfrk
There are 2031 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 7 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
