Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Help on New Build
Help on New Build
Forum Systems : New Build Help on New Build
I'm looking for a little help as I attempt my first build. I have not messed with hardware since I overclocked my TRS 80 a long time ago. I want to build a computer that will not go obsolete to rapidly and that can serve as the storage site on my network. I plan to back up my laptop to this RAID drive. The only power intensive apps I use Dragon NaturallySpeaking and OCR. My first priorities are stability, and quietness. Cost is not such a big issue. So here's what I'm planning to put together and I hope you can let me know if I've gotten anything in here that is obviously wrong. I know this is pretty overpowered for what I am using it for. I am thinking that there may be much more sophisticated voice recognition that requires more power,and I want my voice recognition running as smoothly and quickly as possible. Any thoughts about this?
Mo's Workhorse $948
Processor:
Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I72600 $299.99
http://www.newegg.com/Product/Prod [...] 6819115071
Motherboard:
ASUS P8Z68-V LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $179
http://www.newegg.com/Product/Prod [...] -_-Product
RAM:
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996770 $64.99
http://www.newegg.com/Product/Prod [...] 6820226095
Graphics Card: None
Hard Drive:
Raid 0- (2)Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $89.99X2=$179.98
http://www.newegg.com/Product/Prod [...] 6822136533
Case:
Antec Sonata Elite Black 0.8mm cold rolled steel ATX Mid Tower Computer Case $90
Power Supply:
Antec CP-850 850W Continuous Power CPX SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC "compatible with Core i7" Power Supply $114.00
http://www.newegg.com/Product/Prod [...] c%20cp-850
Cooling: None
DVD Burner:
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM $20
http://www.newegg.com/Product/Prod [...] j3c2g9yw2r
Reply to mostam
Is there any particular reason you chose a board meant for dual vid cards...along with that 850w psu, or is this going to be used for gaming also ?
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
samsung spinpoint f3 1tb's are faster cheaper and quieter than the western digitals they are 60$ at amazon w/ free shipping so switch them out
Reply to mjmjpfaff
Thanks for asking. The 850 w psu is there just because I might need power in the future. I suppose I could downgrade the psu. I thought that z68 mobo allowed me to use the onboard video in the i7 and was a better option than a h67 board. What mobo & psu would you recommend I step down to if I see that as overkill?
Reply to mostam
Here's a few options to look at. First that mobo down below is a bargain at that price. It still allows you to add a discreet vid card in the future and it comes with all the bells and whistles. That psu down below will give you more juice then you most likely will ever need, it's made by Seasonic...which is the best of the best not to mention it's modular... and the 2600K just in case you get the bug one day to push your system.
Also have you thought about an SSD along with a single 1tb h/d? Something to think about.
http://www.newegg.com/Product/Prod [...] 6813157252 $114.99
ASRock Z68 PRO3-M LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6819115070 $314.99
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
http://www.newegg.com/Product/Prod [...] 6817151093 $92.99
SeaSonic M12II 520 Bronze 520W ATX12V v2.3 / EPS 12V v2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.tweaktown.com/reviews/4 [...] index.html <----- Review of that Asrock board
http://www.asrock.com/mb/overview. [...] 8%20Pro3-M <----- ASRock Z68 PRO3-M
http://pro-clockers.com/motherboards/1969/ <----- one more look at that board
Message edited by Why_Me on 07-21-2011 at 01:07:35 PM
Reply to Why_Me
There are 2040 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 2 hours ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
