Help with scratch
Hey,
I was installing my first motherboard today, and I stupidly mis-threaded a screw with one of the case standoffs, resulting in a lot of fiddling around getting it free.
As a result, I have scratched the underside of the motherboard. Most of the damage seems contained to the actual screw 'circle' area. However, I have breached the PCB underneath. I have inspected it with a magnifying glass and it definitely doesn't look like i have severed the copper tracks, but I wanted a second opinion on what I should do.
Close up photograph:
http://i.imgur.com/WJyWQ.jpg
In relation to the rest of the board:
http://i.imgur.com/eVDaf.jpg
Cheers for your help
3 answers Last reply
More about help scratch
  1. No way to repair it, your warranty will be voided, as the board is inspected with any rma request. Only repair is to put a tiny piece of electrical tape over the area by the hole. And I would either replace the standoff that's stripped or leave it empty. Good luck
  2. I have replaced the standoff with a new one. Shall I place electrical tape over the tracks aswell, or leave them as they are?
  3. Just covering the scrapped circuitry lines should be adequate. You can also use a circuit pen to repair breaks but it looks like it won't be needed unless the board won't post.
Motherboards Cases
