Building A New Gaming PC; Need Help
dxboy
Hi, I'm building a new PC for gaming
processor: intel core i5-2500k
motherboard: Asus P8H61-M LE
PSU: Corsair GS800
Please help me deciding:
1. graphics card under $250
2. corsair 4 GB DDR3 ram (which model is best)
3. Can H61 motherboard handle all this configuration and will i get right performance?
Please help.
bearclaw99
529
You will not be able to overclock the 2500K with an H61 motherboard just so you know. Only a P67 or Z68
Video card wise, you're looking at the AMD 6950 Radeon 2 GB if you can find it for $250, otherwise the Nvidia 560 GTX Ti is right behind it
legendkiller
1,812
dxboy
Is it necessary to Overclock ?
Can't I get enough performance with 2500k and a better graphics card without overclocking?
Ripthruster
241
If it's a gaming pc then I think it would be a mistake to get the non-K version. He should get the K and pair it with a P series board. The price difference is negligible and will give it a greater longevity. These cpu's OC a full ghz without even sweating.
