Gts 450 reads dvi connection want hdmi connection
  • Nvidia
  • Control Panel
  • Connection
  • HDMI
  • Graphics
May 14, 2011 7:39:15 PM
I connected my computer to my HDTV via hdmi and it didn't recognize my TV. Went into the Nvidia Control Panel and found that it is reading dvi connector type. My Tv is 3 years old, but has hdmi. Why doesn't it recognize the hdmi? The control panel doesn't give the option to switch over to hdmi.
More about : gts 450 reads dvi connection hdmi connection
May 14, 2011 9:23:17 PM
what cable are you using? HDMI/DVI, HDMI/miniHDMI? update all your drivers. You should know that theres no noticeable difference between the two.
m
l
May 14, 2011 9:31:12 PM
Using HDMI/miniHDMI. My graphics drivers are also up to date, any other drivers i should know about?
m
l
May 15, 2011 2:33:23 PM
I have a program called PC Wizard, gives you the specs of your hardware. I looked at the specs of my card and tells me this:
External Connectors :
Connector Type : DVI-I - (Place : Socketed)
It doesn't show the mini hdmi connector.
m
l
