Solved
Please check if these parts work out
  • New Build
  • Systems
  • Product
Last response: in Systems
July 21, 2011 10:44:43 PM
I am building a computer with a budget of $1000 or less. These are the parts. Would you recommend changing anything? I'm unsure if the PSU wattage is correct and that the cables would be long enough to connect to everything inside the full tower case. I already have a keyboard, mouse, and a monitor.
More about : check parts work
July 22, 2011 1:31:48 AM
PSU wattage is way more than this computer needs. I don't see any problems and it looks like a pretty decent build. Also just to let you know OEM versions of Windows are motherboard bound btw, which means that you would have to either call Microsoft to see if you can get the OEM version of Windows to work on another motherboard or have to buy another copy of Windows 7.
m
l
July 22, 2011 2:26:45 AM
for 1000$ you can build a way more powerful i5 2500k rig.
m
l
Best solution
July 22, 2011 5:02:00 AM
http://www.amazon.com/Cooler-Master-Enforcer-Interior-S... $79.99 & this item ships for FREE with Super Saver Shipping
Cooler Master Storm Enforcer USB 3.0 Mid Tower ATX Case with Window and Black Interior (SGC-1000-KWN1)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $94.99 - $69.99 after mail-in rebate FREE SHIPPING
Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... $169.98 save: $35.00
GIGABYTE GA-Z68X-UD3-B3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... You Save: -$15.00 $444.98 $20.00 Mail-In Rebate Card Price After Mail-In Rebate(s): $424.98 FREE SHIPPING
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
ASUS ENGTX560 TI DCII TOP/2DI/1GD5 GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.amazon.com/gp/product/B002G1YPH0/ref=ox_sc_a... $29.49 & this item ships for FREE with Super Saver Shipping
Cooler Master Hyper 212 Plus 120mm Sleeve CPU Cooler, RR-B10-212P-G1
http://www.amazon.com/Samsung-Spinpoint-3-5-Inch-Intern... $59.99 & this item ships for FREE with Super Saver Shipping
Samsung Desktop Class Spinpoint F3 1 TB SATA 3.0 Gb-s 32 MB Cache 3.5-Inch Internal Bare-OEM Drives, HD103SJ
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $19.99 FREE SHIPPING
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $99.99 FREE SHIPPING
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Total: $999.00 *not including shipping and mail in rebates
July 22, 2011 4:34:38 PM
If it's more than the computer needs then that means I can add stuff on in the future :D
m
l
July 22, 2011 5:57:09 PM
Hello ? I'm going to guess you started this thread on here in the hopes of getting the best for your money. This is a gaming build correct?
First off that 1100T is a dud. Second that 6850 is a mediocre card at best not to mention that Earthwatt psu is mediocre also. $1,000 budget...
http://www.anandtech.com/bench/Product/203?vs=288 <----- AMD Phenom II X6 1100T BE vs Intel Core i5 2500K benchmarks
It gets even worse for that 1100T when it comes to over clocking.
http://www.maximumpc.com/article/videocards/asus_engtx5... <---- benchmarks on that Asus 560 ti
m
l
July 22, 2011 8:31:47 PM
why_me's build is way better than the one you originally posted
m
l
August 1, 2011 3:34:39 AM
Thanks Why_Me, I ordered the parts for the build you recommended for me. Is it future proof though?
m
l
August 1, 2011 3:34:47 AM
Best answer selected by samn122.
m
l
