Hey guys, I am wanting to upgrade this spare pc I have and was wondering a few things. First of all here is the specs for the pc:
Windows XP (Upgrading this to Vista (yes I know lol))
2gb ram
2.7ghz intel duo
450w crap psu
Crap video card
EVGA NF66 650i ultra mobo
My main objective is I want to be able to play Starcraft 2 on low/medium settings without lag/framerate issues.
Now the processor should be fine (I think?) the 2gb of ram is kind of low but should work.
Here is the mobo I have: http://www.newegg.com/Product/Product.aspx?Item=N82E16813188017
Here is the video card I'm thinking about getting: http://www.newegg.com/Product/Product.aspx?Item=N82E16814133390
Says the minimum requirement of power supply watts is 300 with a 12v rating of 18A.
The power supply I'm getting is a Black 600w Silent ATX Power Supply w/20+4pin SATA from powork. It has a 12v rating of 24A.
I guess my first question is would that video card and psu work on that mobo? The video card is a pci express x16 2.0 but the mobo's slot isn't a 2.0, that shouldn't really matter should it?
My second question is would that video card be able to run Starcraft 2 with the aforementioned details?
My third question is will that psu do it's job good enough for it all to work?
Sorry for the lengthy post, I am just unsure about these things and could really use your input.
Thanks guys!
2gb ram
2.7ghz intel duo
450w crap psu
Crap video card
Thanks guys!
