I'm trying to pick out parts for a new gaming build. I'm planning on playing lots of new games on it such as Guild Wars 2 and Skyrim.
Budget Range: Hoping between $1500-$1700 before rebates.
System Usage from Most to Least Important: Gaming!!!
Parts Not Required: none
Preferred Website(s) for Parts: newegg.com
Country of Origin: US
Parts Preferences: Razer keyboard
Overclocking: maybe
SLI or Crossfire: maybe later
Monitor Resolution: need one so I guess I should probably go with 1920x1080?
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz LGA 1155 $220 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
MoBo: Not really sure what to look for in a mobo
Heatsink: COOLER MASTER Hyper 212 Plus $29.49 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Graphics: SAPPHIRE 100312-1GDP Radeon HD 6950 1GB 256-bit GDDR5 $245 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102949
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 $65 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM $60 http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Optical: SAMSUNG CD/DVD Burner $19 http://www.newegg.com/Product/Product.aspx?Item=N82E16827151233
Case: COOLER MASTER HAF 912 $55 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Mouse: RAZER Naga $80 http://www.newegg.com/Product/Product.aspx?Item=N82E16826153054
Keyboard: I think RAZER would go with the mouse, but I can change both if there are cheaper and better ones.
Speakers/Headset: not sure, some insight would be nice
OS: Windows 7, I don't know where to get it the cheapest
Monitor: No clue what to get.
I don't think I forgot anything.
Overclocking: maybe
