Okay, I have decided to build my first gaming computer myself. Before ordering anything, is there anything that won't be compatible, is weak or a bad product, and do you think this build is quality enough to run gta 4 on high settings after I OC the cpu? Thanks.
MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131672
CPU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.677559
CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181011
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104206
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148701
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152035
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146025
DVD Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500194
Total: 681.98 after tax and shipping, but before rebates.
Any way to get a cheaper build with similar performance on gta 4?
Also, my resolution shouldn't very high as ill be on a fairly small and inexpensive monitor.
MOBO
CPU
CPU Cooler
RAM
HDD
PSU
Case
DVD Drive
GPU
