Hello everybody,
I'm almost finished with my new build (my first build), however, I'm confused about what to connect to my new motherboard (Rampage IV Extreme) from my power supply unit (Cooler Master 1200W, 80 Plus Gold) for the CPU (Intel Core i7 3960X). I see a 4-pin and a 8-pin socket at the top of the motherboard, however the 8-pin socket came shipped with a removable plastic cover that is covering only half of the 8-pins.
My question is do I need to use both the 4-pin and 8-pin sockets to power my Intel 3960X CPU? Since the 8-pin socket has a plastic cover that's covering half of the 8-pin socket do I need to remove that and use the full 8-pins in conjunction with the 4-pin socket? Or just the 4-pin and 8-pin socket with the cover on? I didn't see any of this in the motherboard manual. I would greatly appreciate any help. Thank you!
My System:
CPU: Intel i7 3960X Extreme
Motherboard: ASUS ROG Rampage IV Extreme
Ram: G.Skill Ripjaws Z 8 Gigs 2400Mhz
GPU: EVGA GTX 690 Signature Edition
PSU: Cooler Master 1200W Silent Pro 80 Plus Gold
HS/F: Cooler Master TPC-812 2 Vertical Vapor Chambers/6 HS Pipes
Sound Card: Sound Blaster SFX
Case: ICTE Quad Fan Support
HDD: Hitachi 320 Gigs 7200 RPM's
Disc Drive: LG Super Multi DVD RW+
Monitor: Dell 24" Ultra Sharp Flat Panel
OS: Windows 7 Ultimate
My System:
