Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] Intel Celeron D 3.33ghz OVERHEATING PROBLEMS!!!!!!!!
Forum CPU & Components : CPUs [Solved] Intel Celeron D 3.33ghz OVERHEATING PROBLEMS!!!!!!!!
Best answer from geofelt.
Hey all. I have an Intel celeron D 3.33ghz, and my Bios is telling me that it runs at 62 degrees Celcius. That's on idle. I don't know what to do. I think tomorrow im going to try applying new thermal grease. Also, I took my cpu fan off of the cooler and replaced it because it was SOOOOOOOOO noisy. I replaced it with a 4 bin molex connector instead of one that hooks into the motherboard. Does that make a difference as well? Please help me. Im in desperate need of help.
Reply to knightird
When the computer is on is the CPU fan spinning? Also is the fan and heatsink stock or aftermarket and is the CPU overclocked? I would check the fan and then reapply thermal paste and reseat the heatsink. Make sure it's seated firmly in place and as straight as possible.
Message edited by Rds1220 on 10-21-2011 at 01:50:49 AM
Reply to Rds1220
Best answer
Most likely, you have not mounted the cooler well.
A common mistake is to use too much paste. The purpose of the paste is to fill in microscopic pits in the mating surfaces.. No more.
If you use too much, it acts like an insulator. It is hard to use too little. A small bb sized dollop in the center is all that is needed. It will spread by itself.
To mount the Intel stock cooler properly, place the motherboard on top of the foam or cardboard backing that was packed with it.
The stock cooler will come with paste pre applied, it looks like three grey strips. Do not try to reuse the paste. Clean the surfaces with denatured alcohol and a lint free coffee filter.
The 4 push pins should come in the proper position for installation, that is with the pins rotated in the direction of the arrow,(counter clockwise) as far as they can go. Since you have removed the cooler, play with the pins so you understand how they work.
Place the cooler so that all 4 pins are oriented over the holes in the motherboard.
The trick to getting it on is to push down on a diagonal pair of pins at the same time. Then the other pair.
If you do them one at a time, you will not get the cooler on straight.
Lastly, look at the back of the motherboard to verify that all 4 pins are equally through the motherboard, and that the cooler is on firmly.
This last step must be done, which is why the motherboard must be out of the case to do the job.
It is possible to mount the cooler with the motherboard mounted in the case, but you can then never be certain that the push pins are inserted properly.
If you should need to remove the cooler, turn the pins clockwise to unlock them. You will need to clean off the old paste and reapply new if you ever take the cooler off.
All motherboards I know of have a 3/4 pin cpu fan header. Use it. If the header is not populated, the motherboard will think you have no fan and severly downclock your cpu, and perfaps refuse to run.
Reply to geofelt
Old Netburst CPUs run hot, though I'm guessing on that one the heatsink has some dirt and stuff on it. If there is space in the case I would replace it with a cheap, decent tower cooler like a Cooler Master TX3, though I'm guessing on this one you may have just replaced the fan. The reason it was so noisy was because the motherboard ramped up the speed to cool the chip.
Reply to megamanx00
I put it on as straight as possible, I haven't overclocked it yet, it was a little dirty, and the thermal grease looked really worn out on the cpu. Should I try replacing the thermal grease?
Reply to knightird
Mine doesn't have pins. It has 4 screws on it instead of 4 pins...
Reply to knightird
Also, the fan is running because I have the side of the case off because the inside of the case severely overheats when the side is on. I think im gonna replace it soon, because it's just the standard emachines that it came in...
Reply to knightird
Yes re-apply the thermal paste. Use 99 percent rubbing alcohol and coffee filters to clean off the old thermal paste and re-apply. Make sure you keep wiping until the coffee filters comes out clean. If you don't wipe all the old thermal compound off it can cause more heat problems.
Reply to Rds1220
O.K I don't have any coffee filters so would a paper towel work as well.
Reply to knightird
Also, I need a solution for a case that is good for cooling. I have two servers and they both overheat when their sides are on. I don't know how many times I got my fingers in a spinning fan on them two when the sides are off. It hurts really bad. I need to know a good pc case...
Reply to knightird
You want something lint free. Coffee filters have worked for me. If the towel has lint, find something else. A piece of lint left on the surface will be a major problem.
Exactly what cooler do you have?
If it is the stock intel cooler, it will have pushpins which might look like screws.
A picture would help if you don't know.
Reply to geofelt
It's not an intel cooler. I don't know what kind it is, but I replaced it with a 4 pin molex connector, and they are screws. I had to unscrew them and rescrew them in to the motherboard.
EDIT: I replaced the fan with a four pin molex connector.
Message edited by knightird on 10-21-2011 at 02:21:31 AM
Reply to knightird
The Antec TWO HUNDRED is a good, cheap well cooled case. It has a washable intake filter. You can add front intake fans, but it is probably not necessary:
http://www.newegg.com/Product/Prod [...] 6811129074
Reply to geofelt
You can use paper towels but you really shouldn't because they cause a lot of lint which could stick to the thermal paste and cause problems. It's best to use something that will cause no lint flakes like a non lint cloth or non lint coffee filters. How much do you want to spend on a case and what size tower do you want.
Reply to Rds1220
It doesn't matter on what kind of case or how big it is. Right now, money isn't a problem as long as it's not over $150.00
Reply to knightird
Then I would say something like this from Antec. It's cheap but still not bad for the price. With 2 200mm fans it should stay pretty cool.
=http://www.newegg.com/Product [...] 811129097]
Message edited by Rds1220 on 10-21-2011 at 02:32:48 AM
Reply to Rds1220
What about the Thermaltake Chaser MK-1
Reply to knightird
The Antec 300 illusion is a popular case. It comes with some added fans @$70.
http://www.newegg.com/Product/Prod [...] 6811129066
@$140, look at the Antec 1200 V3:
http://www.newegg.com/Product/Prod [...] 6811129100
Reply to geofelt
What about the thermaltake chaser mk-1
Reply to knightird
There are 2037 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 7 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
