Tom's Hardware > Forum > Digital Camera > Digital Camera General > Going to the Races, Need Some Advice
Forum Digital Camera : Digital Camera General - Going to the Races, Need Some Advice
Archived from groups: rec.photo.digital,rec.photo.digital.slr-systems (More info?)
Going down to Atlanta tomorrow to catch the NASCAR events and I wanted some
general advice on what I should bring.
1) I'm planning on taking my 300D of course along with my 100-400 and my
28-135. I'll be taking shots from the stands and pit road. I'm hoping to
get some good action shots; we'll see. In any event, unless some one can
give me a compelling reason why, I hadn't planned on taking my 18-55 or my
cheap 75-100. Thoughts?
2) I have a Lowpro waist bag, similar to
http://www.lowepro.com/Products/Be [...] ion.aspx,. It holds
everything but the 100-400, however, I find it sort of bulky. I was
thinking of stopping by the local shop today and looking at a belt solution
with a lens case for the 100-400 and the 28-135, a top load case for the
camera, and an additional case for accessories and CF cards. I'm thinking
this will be easier to handle on the plane and at the track. Any thoughts
or suggestions?
3) Any other suggestions would be greatly appreciated.
TIA
Rob
Sponsored Links
"Robert R Kircher, Jr." <rrkircher@hotmail.com> wrote in message
news:ZLGdnZqPYtgg56TfRVn-sA@giganews.com...
> some general advice on what I should bring.
> solution with a lens case for the 100-400 and the 28-135, a top load case
> for the camera, and an additional case for accessories and CF cards. I'm
> thinking this will be easier to handle on the plane and at the track. Any
> thoughts or suggestions?
> TIA
> Rob
Tamrac makes lens cases to go with their top loader camera holsters, this
might be less bulky than the belt pack. I have a Tamrac 519, which holds my
20D and either my 28-135 IS or 100-400 IS, so a single lens case big enough
for the 100-400 would be all you need. Be forewarned, though, the flash
won't fit in the outside pocket with the 100-400 in the case. If you're
taking a flash, you'll need a separate case for it...
All of the images on this gallery were taken with the lenses you mention,
except for the Stutz fuel tank:
http://www.shutterspeedway.com/cgi [...] +the+Races
Have fun!
Skip Middleton
http://www.shadowcatcherimagery.com
Reply to Anonymous
> or suggestions?
I'd take a max of two lenses. One for long one for medium. (28-135/
100-400) although on a cropped camera you might find the 28 limiting.
You might get the "no professional equipment allowed treatment" as you
try to get in. Have a backup plan on where you can store your "pro"
equipment if you get refused entry.
Cheers,
Alan
-- r.p.e.35mm user resource: http://www.aliasimages.com/rpe35mmur.htm
-- r.p.d.slr-systems: http://www.aliasimages.com/rpdslrsysur.htm
-- [SI] gallery & rulz: http://www.pbase.com/shootin
-- e-meil: there's no such thing as a FreeLunch.
Reply to Anonymous
I don't think you'd get much from the 75-100. When I go racing (a lot) I
find that most of my pictures are either paddock shots where I'm right
down round 28mm trying to get as much as I can of a car in shot,
trackside stuff at round about 100 where I'm trying to frame a car in
the landscape, or stuff from stands or spectator areas where I'm out at
200 or beyond. (All numbers equiv., as I use a Panasonic FZ-10.
Personally I'd say the 18-55 for pitlane, "atmosphere" and detail shots
(18mm gives some interesting options for wide-angle shots) and the 100-400
for the race.
I've only photographed race cars once before from grandstands round an oval
(Rockingham, but not the one you're thinking of, the one in the UK; most
of the racing I attend is on road courses) -- fortunately ovals are
pretty compact so you probably won't need to go out to 400 to get good
action shots of the cars.
I don't know how fast those lenses are - but for good action shots I
find that having the lens wide open (so you get a good focus on the
subject and a fairly soft background) and the shutter speed as fast as
it can go is the route to decent pics.
Finally, remember that your camera may well decide that it wants to AF
on chain-link fence rather than what you're pointing it at. ;) You may
find that working with manual focus helps. ;)
pete
pete@fenelon.com "Send lawyers, guns and money...."
Reply to Anonymous
- 0 +
Archived from groups: rec.photo.digital (More info?)
Two camera bodies. Then your lens concerns are not that much of a
concern.
Wes
Reply to:
Whiskey Echo Sierra Sierra AT Gee Tee EYE EYE dot COM
Lycos address is a spam trap.
Reply to Clutch
"In any event, unless some one can give me a compelling reason why, I hadn't
planned on taking my 18-55 or my cheap 75-100. Thoughts?"
http://www.harryphotos.com/miketruckfinal.jpg
shot at 18mm with the stock rebel lens(sky was added)...but you should be
able to get in even closer and have everything sharp for a cool look...the
28mm is 45mm in 35mm format (excuse my bad wording) so it's not very
wide...
Reply to Anonymous
Good for you.. (I'll just be watching on TV :)
I'd leave the 75-100 at home, but I'd take the 18-55.
Atlanta is a big place.. You might want to capture the whole
track from the stands.. Your 28-135 might not be wide enough
at 28mm.. I'd want the 18mm to augment my shooting options.
> or suggestions?
I've got a Lowepro OmniTraveller. I found this site that shows
what it looks like:
http://www.asvd07.dsl.pipex.com/ni [...] veller.htm
It has padded adjustable partitions that attach with velcro so
you can move them around and configure the bag to snugly carry a
variety of lens shapes.
I can squeeze in my EF 28-135, my EF 50mm f/1.8 and my EF 100-400
along with the 10D, filters, cables, mem cards, lens cleaning stuff
spare batteries and a 420EX flash :)
Reply to Anonymous
One thing I found shooting CASCAR races a couple years ago, is to set
your exposure manually. Meter it off the tarmac or start with Sunny 16
and lock it in. Otherwise you get too many pictures of black/dark cars
coming out grey with washed-out backgrounds, or white/light cars coming
out grey with really dim backgrounds. Metering will vary as you go
around the track as well, between front-, side- and back-lighting
(especially if you're in the pits). My best results have come from
setting the aperture wide open, then locking in the appropriate shutter
speed, and just leaving it there.
Reply to Anonymous
> TIA
Thanks everyone for you help. Unfortunately the local shop didn't have much
to offer in belts so I'll be taking my current case.
Rob
Reply to Anonymous
In article <QBk_d.708337$Xk.572242@pd7tw3no>,
Excellent advice. Just be careful if there's a situation where the
cars are moving into (or out of) shadows, and meter on the right part.
> My best results have come from setting the aperture wide open, then
> locking in the appropriate shutter speed, and just leaving it there.
That's appropriate when the cars are coming towards you. For a side
shot too high a shutter speed results in it looking as though the cars
are parked on the track. You want a little blur on the wheels, if
you can manage it. Here's an example taken at 1/200 of a second:
<http://panix.com/~johnf/temp/LSQualifying.jpg>
(You need to pan during the exposure to blur the wheels, not the car)
That car is probably travelling at the same sort of speeds you'll see
at Atlanta. I wouldn't recommend starting at 1/200 if you've never
tried panning to keep the car fixed in the frame during exposure;
it's a learned skill. But you should definitely try several shots
with a shutter speed around 1/400 of a second; that's a lot easier.
Of course, depending on the light, 1/400 might very well be the
shutter speed you get with the lens wide open; it depends on the
ISO setting you've chosen. In that case I'd suggest leaving it
set that way for side shots, but selecting a higher ISO value
for any head-on shots; I like a shutter speed of 1/750 or faster
in those situations.
Reply to Anonymous
There is that. Another option is to find a decent shutter speed for
the effect you want to achieve (1/200 if you're comfortable with
panning) and then locking the appropriate aperture - if you have good
sunlight, shooting at ISO 100 should allow you to use f/8, which should
allow you both to get a little blur on the side shots, and provide a
little extra DOF for the straight-on shots (not that my Rebel's AI focus
has ever had much trouble tracking the cars :)
BTW, on the topic of lens cases/bags, I found a nice little case
(probably a Lowepro) designed for a pocket digital camera that has a
velcro loop on the back to allow you to slip it over any regular belt, a
zip top that opens partway down the front for easy access, a few small
compartments to hold things like my spare batteries, and just enough
room to nicely fit my Canon EF 75-300 zoom. Works great for
quick-changing between two lenses (such as the EF 28-90 on my old
RebelG, and the EF-S 18-55 on the DRebel).
Check any consumer-electronics store that has a good selection of
pocketable digital cameras, and they should have a good selection of
those little camera cases too.
Reply to Anonymous
In article <3q%_d.727414$6l.313540@pd7tw2no>,
The trouble with 1/200 for a straight-on shot is that you can't pan
to track the cars, so you're going to end up with some blurring; at
the sort of speeds typical for NASCAR/CASCAR a car will move anything
up to 18" (50cm) during a 1/200 second exposure. While most of that
is towards you, and thus has only a minor effect on the image, it's
still enough to show up on sharp edges (such as the sponsor decals).
I prefer 1/750 to 1/2000 for head-on or front three-quarter shots.
Of course that means you have very little depth of field (especially
if you are using a long focal length), so you can't just rely on
the af system unaided - you're a lot better of selecting a single
af point (otherwise you'll end up with the wrong part of the car
in focus; you want the driver, if you can see him, or the nose).
Reply to Anonymous
True too. Unfortuantely I don't remember entirely what settings I used
at the time... most of it was in good sunlight, which helped... probably
ISO400 film... 1/1000 at f/8 would be likely.
As my audio engineering instructor always told us, "There are no rules,
only guidelines." :)
Reply to Anonymous
> TIA
Thanks again for everyone's help, I had a great weekend and managed to get
what I think are some pretty good shots using much of the advice given.
I'll posting links to the shots later today.
Rob
Reply to Anonymous
Archived from groups: rec.photo.digital.slr-systems (More info?)
On Thu, 17 Mar 2005 07:40:29 -0500, "Robert R Kircher, Jr."
>http://www.lowepro.com/Products/Beltpacks/classic/Orion.aspx,. It holds
>or suggestions?
>TIA
Your probably gonna laugh at this but: I usually use 3 lenses, and
pop 'em in an out alot. A 10-22m, 18-55, and a 75-300 is. After
looking in camera shops and alot of diff places...i got a cheap $5 -
made somewhere in asia- leather (proabably rodent or marsupial) giant
fanny pack. The kind with the seems..looks like patched black leather.
It's great. Slide it off to my hip when i gotta cover distance and in
front for quick changes and slapping a polarizer on or hand holding
a cokin medium density. One lens is always on the cam, and 2 in
the pouch. The 75-300 goes horizontaly, the the shorters
vertical. Also is a rubber ball aspirator - makes a good seperator.
The 2 polarisers and cokin go in the pocket in the front and
lense tissue in the little side pockest. Things got alot of pockets.
It works for me. Have a small versions that goes to the other
side (criss-cross) that holds a dig-cam (sony f707).
Carhardt makes a dandy constuction grade coat with giant
pockets. Lined and unlined. Lens per pocket. with lots of
room to spare. Cameras always around the neck. If your
two lenses are really long..and it's down south..i'd go with
a light-weight construction coat or vest for that matter.
You gotta be able to get at it quick, use both hands
and you don't want it flappin around - need the stuff
close to your body. In tight but easy to grasp.
rgds
Ken
Reply to Anonymous
There are 904 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
