Solved
HELP me choose corsair tx850 v2 or not ..!!
should i go for Corsair TX850 V2 (850W) smps or not
i am planning to buy the below parts at the moment in next 2 days
motherboard =P8Z68-V
processor =i5-2500K
single graphics card =MSI N560-Ti Twin Frozr II 2GD5/OC
genaral hard disk 1tb , dvd-rom and 8gb corsair ram
i tried shops near my area in india.. but the
Corsair TX750 V2 80Plus Bronze Cert. is not available with the retailers
but retailers have the stock of
Corsair TX850 V2 80Plus Bronze Cert.
they are offering me this supply for my build
(for readers convenience)Here’s a review:
http://www.overclockersclub.com/reviews/corsair_tx750_tx850_v2/10.htm
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=218
i dont know how to calculate psu wattage,and i dont even know how accurate it is
but i googled and keeping this link too (for people who have the knowledge on it and save their time to suggest me)
http://extreme.outervision.com/psucalculatorlite.jsp#footnote5
MY question is ....
1) How much is an avg normal wattage power consumption...of tx850 v2 psu
consumed for the normal computing like internet surfing,
listening to songs,watching you tube videos ,
general mid level gaming (need for speed most wanted are the game i like most and keep on playing them)...if the above system parts are used .....
will it consume a lot of power ??
should i go for a lower level psu ??
2)is power consumption of 650txv2 /750tx v2 / 850 tx v2 same ??
if a similar load is applied on all the three individually
3)Will the APC 800va UPS enough for the 850txv2 ..??
7 answers Last reply Best Answer
More about help choose corsair tx850
  1. The 850 is more than you need right now,
    the 750 would have been more in line with your needs but the psu will only draw what you need from the wall,
    add your Cpu and graphics cards wattage requirements together, add about 20w for Mobo and drives to get an idea of the draw
    ups depends, how reliable is your local electricity supply?
    if its none too shiny then yes grab one
    Moto
    Moto
    i also felt to go with 750 but ,
    as its not available at the store and i am going to make the deal
    the retailer is offering me 850
    your words " psu will only draw what you need from the wall "
    gave a positive feeling to me...
    does your words means to say...
    the consumption of either a 650tx v2 / 750tx v2 /850tx v2 will be same all the way...
    if similar load is applied on 3 of them ??
    pls reply me ...... and thnx in advance for the early reply
  3. Best answer
    yes, your psu will only take from the wall the power that it needs to use
    so a 650,750 or 850 will all use the same amount of power, just the two bigger units will have more headroom or capacity
    Moto
  4. pls tell your opinion
  5. Quote:
    Moto
  6. I dont know about ups's I'm afraid, I've never had the need for one so haven't researched them sorry
    Moto
  7. Best answer selected by izhan22.
Power Supplies Corsair Components
