550w Power Supply with 6970
Are there any good programs out there where I can monitor my power usage?
Also do you guys think I could run a 6970 with a 550w Power Supply? It says 550 is the minimum requirement for the card on AMD's website
My Current System Specs are:
Antec NeoPower 550W power supply
i5-2500K
12 gigs of CORSAIR Vengeance
2 Hard Drives
1 DVD Drive
4 Case Fans
Sound Blaster X-Fi PCI card
Thanks much!
1 answer Last reply
More about 550w power supply 6970
  1. That PSU has 504watts available on the +12 volts so it should run it fine. http://www.antec.com/Believe_it/specs/NeoPower550_spe.html
Power Supplies Power Components
