24pin PSU compatible with 20 pin motherboard input?
I have a GA-D425TUD motherboard which has a 1 x 20-pin ATX main power connector.
My power supply unit has a 24 pin output, is it compatible? Do I need a cable or do I have to toss the PSU?
1 answer Last reply
More about 24pin compatible motherboard input
  1. The 24 pin connector is compatible. Actually, four of the pins break away from 20 of the pins, so you really have a 20+4 connector.
Motherboards Power Supplies Compatibility
