My first Build Need Help!!!
I know how to build my own computer but I dont Know if the components will work together the site I am buying the off is komplett.ie the components are as follows
Inwin Dragon Slayer Micro ATX Black,
Sony Optiarc DVD±RW burner AD-7260S Black,
Corsair XMS3 - 8GB 1333MHz PC3-10600
DDR3 - 240 pin - 1.5V - CL9 - KIT,
MSI Radeon Cyclone HD4890 - 1GB PCI-E 2.0
1GB - DDR5 2 x 6 pin PCI-E,
HI 3.5" SATAII 1TB/7200RPM/32MB HITACHI,
MSI A75MA-G55 - motherboard - micro ATX - Socket FM1 - AMD D3,
AMD Athlon II X2 260 3.2GHz 2MB AM3 Box,
CoolerMaster Silent Pro M700 - power supply - 700 Watt
4 answers Last reply
More about build help
  1. The motherboard is made for the new AMD APU's and uses FM1 socket. You need to be looking at AM3 or AM3+ socket motherboards. In the microatx for factor which is what your case is.
    The case, memory , DVD burner and the HDD are fine.
    Seems like the choices for motherboards are quite limited on the site, possibly get an intel combination since the choices are much better.
    ASUS P8H67-M LE
    93€
    i3 2100 109.95€
    Then get a good PSU like Corsair TX650 V2 86.95€
    The HX750 would be much better but also 50€ more, so if you can afford it great, if not the TX will do.
    For video card i recommend getting something a little bit newer that supports directX 11, granted it is pretty powerful and it is quite cheap at the 87€ price, but still you should get something like HD6770, GTS450 or GTX550Ti which are a touch more between 93-120€
  2. Great man thanks alot would this system be alrite so
    ASUS P8H67-M LE - Motherboard - micro ATX - iH67 -
    LGA1155 Socket - SATA-300 (RAID), SATA-600 (RAID),
    Processor - 1 x Intel Core i3 2100 / 3.1 GHz -
    LGA1155 Socket - L3 3 MB - Box,
    Sapphire RADEON HD 6750 - Graphics adapter -
    Radeon HD 6750 - PCI Express 2.1 x16 - 1 GB GDDR5,
    No PSU,
    24x (DVD±R) - DVD-RAM - S-ATA - internal - 5.25",
    ADATA - 4GB 1333Mhz PC3-10666 DDR3,
    Corsair TX650 V2
    I put the HD6750 in instead cause its cheaper and the same ting really but i tink its downgrade of the HD6770 wat u tink will it work together
  3. make sure you get 2x2GB kit of the memory and that it has 1.5V voltage.
    So that you can take advantage of the dual channel memory.
    I would recommend getting the 6770 instead. Since it's not many euros more than the 6750.
    And there is a big enough difference in performance so that you get a better deal.
    Other than that it's looking good.
  4. Right great help man I shall do I supose the graphics card isnt that much more
    Thanks for your help
Build Systems
