I have an old Dell Inspiron 530 that I took everything out of and transferred to an Antec case. I cannot figure out how to get the front panel mic and headphone jacks to work. Apparently Dell uses a non-standard front Audio connector.
I'm thinking of doing it pin by pin. The motherboard is a Foxconn G33M02. This is a picture of it. http://img.techpowerup.org/100101/12111702240064.jpg
The audio connector is yellow near the top left corner of the picture with 9 pins.
These are the instruction for the Antec case connectors.
1. Microphone Signal Pin: Connect the MIC connector to this pin.
2. Microphone Power: Connect the MIC-BIAS connector to this pin.
3. Ground Pin: Connect the AUD GND connector to this pin.
4. Front Right Speaker Out Pin: Connect the FPOUT-R connector to this pin.
5. Front Right Speaker Out Pin: Connect the FPOUT-L connector to this pin.
6. Rear Right Speaker Out Pin: Connect the RET-R connector to this pin.
7. Rear Left Speaker Out Pin: Connect RET-L connector to this pin.
Couldn't find a working download link for a manual of the motherboard. Help please.
