My Amd athlon x3 440 unlocked to x4 b40 keeps shutting down while playing bad company 2. I know its the cpu because right after I touch the heatsink its literally hot enough to boil eggs and when i turn it on the cpu temperature is in the 70+ Celsius (shutdown temp is 80ish).
I wiped clean and put new thermal grease 2 months ago but lately the computer has been on for 16 hours or more a day and idles around 50C.
Which of these coolers would be better considering I wont overclock.
The cooler master 212
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Or Arctive freezer 7 rev 2?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
The room is usually in the mid 70s.
I also have a gts 250 video card if that makes a difference. My case door is usually open and the case is one of the simple cooler masters with the mesh front.
I just want it not to overheat enough to shutdown while playing.
