Solved
Power Supply
I am looking for recommendations for decent but inexpensive power supply for this case:
www.newegg.com/Product/Product.aspx?Item=N82E16811163166
It will be a low-cost internet/e-mail machine and am going to use the following:
Intel BOXD525MW Intel Atom D525@ 1.8GHz (Dual Core) BGA559 Intel NM10 Mini ITX Motherboard/CPU Combo
Crucial CT25664BC1067 2GB 204-PIN PC3-8500 SODIMM DDR3 Memory Module
Western Digital Caviar Blue WD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Thanks!
2 answers Last reply Best Answer
More about power supply
  1. Best answer
    Typical "full size" ATX power supplies fit in that case.
    Corsair 430w. Overkill in size, but good price.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
    Antec EarthWatts 380w. Old standby...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
    Seasonic 300w
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151085
  2. Best answer selected by AWKIII.
New Build Power Supplies Intel Systems Product
