Sign-in / Sign-up
First Time Builder, Need Some Help
  • New Build
  • Systems
  • Product
Last response: in Systems
July 26, 2011 2:01:24 AM
:hello:  Hi,
My name is Max
I am a first-time builder and I need some help.
These are the parts I want to get for my build:
CPU: AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
RAM: Kingston HyperX Blu 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9AD3B1K2/4G
Power Supply: COOLER MASTER Elite 460 RS-460-PSAR-J3 460W ATX12V V2.31 Power Supply
Graphics Card: SAPPHIRE 100287L Radeon HD 5670 (Redwood) 512MB 128-bit DDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Motherboard: ASRock M3A770DE AM3 AMD 770 ATX AMD Motherboard
HardDrive: Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Case: HEC Blitz Black Steel Edition ATX Mid Tower Computer Chassis Gaming Case w/ Front Blue LED 120mm Fan & Top 120mm Fan
CD/DVD Burner: LG DVD±RW SuperMulti Drive 22X DVD+R 8X DVD+RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model GH22NS50 Bulk - OEM
(All above available at newegg.com)
So, basically I want to know if all these parts will work together (i.e. compatibility). I also want to know if there are any problems with the parts i selected (compatibility, not enough power for power supply, overclocking, etc.).
If there are any flaws can someone please point them out to me and help me by maybe suggesting an alternate part(s)?
Help is appreciated :)
More about : time builder
July 26, 2011 2:37:35 AM
What's your budget, builds intended use, and screen resolution.
m
l
July 26, 2011 3:13:40 AM
Yea budday:)  You need a budget first before we suggest anything and by the looks of it your gaming. Also im curious to know ur old build? Maybe reuse some stuff, save you money
m
l
July 28, 2011 4:21:19 AM
my budget is 400-450$ and the only parts i have are old
m
l
July 28, 2011 7:12:12 AM
OH and States or canada?
m
l
July 28, 2011 5:18:05 PM
California
m
l
July 29, 2011 8:36:53 AM
all the parts are on newegg
m
l
July 29, 2011 6:44:27 PM
thanks for the link StarRavier.
Just to make sure, the parts i pick WOULD work right?
m
l
July 29, 2011 7:18:50 PM
pretty bad build...with 450-500$ you can have a brand new AMD LLano system!
m
l
July 29, 2011 7:25:59 PM
Xigmatek ASGARD II B/S CPC-T45UD-U01 Black / Silver 0.8 mm SECC / Aluminum and Aluminum Mesh Bezel ATX Mid Tower Computer Case
SeaSonic SS-300ET Bronze 300W ATX12V V2.3 80 PLUS BRONZE Certified Active PFC Power Supply - OEM
AMD A8-3850 Llano 2.9GHz 4MB L2 Cache Socket FM1 100W Quad-Core Desktop APU AD3850WNGXBOX
GIGABYTE GA-A75-D3H FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Kingston HyperX X2 Grey Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model KHX1600C9D3X2K2/4GX
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
SUM 434$
m
l
July 30, 2011 5:09:22 PM
SUM 434$
A X3 455 + HD5770 still offers more gaming power for the money though.
m
l
